Complex Select/Filter using 3 Data Masters
Russell Hutson shared this question 7 years ago
Hi
I have two data masters: Customers and Orders.
Each have an id column.
I have a third datamaster called CustomerOrdersMap, which maps the Orders to Customers like this:
customerid=1
orderid=2
customerid=1
orderid=3
customerid=2
orderid=1
So customer 1 has two orders.
I'd like to update an Orders Data Grid when a customer is selected (e.g. using an input called customerIdInput) as follows (in SQL)
SELECT * FROM Orders WHERE orderid IN (SELECT orderid FROM CustomerOrdersMap WHERE customerid=customerIdInput)
How can I do that using SELECT / FILTER etc?
Russell
Wow, you are going so far with Prototyper! That's cool! Well, I've been able to build the expression you need to simulate that. It's quite complex so I think the best is to show it to you in a prototype so you can see how it works http://justinmind.s3.amazonaws.com/n_...
Thank Victor! It worked!
I didn't think of using the 'has' function, ...that was the key.
For others reading this in a hurry....
75832011ce2eaa7b442ff00931ce9a17
You're welcome!
