Checkbox variables not working
Tjiper shared this question 8 years ago
how can i use a variable for a checkbox? its not showing anything at all, i used the variable for the checkbox like the radiobuttons but the radiobuttons works and checkbox doesnt.
TIA,
Comments (11)
May I ask you a couple of questions to figure out what could be the error? How do you display the value of the checkbox after you stored it in the variable? Are you showing the value in another checkbox or in a label? How do you store the value in the variable? Do you use an onclick-set value or a onPageUnload- Set value?
Thanks in advance.
hi thanks for your replay,
i am trying to display the value of the checkbox using another checkbox in another page.
I store the value using onpage-unload action using a set value on the variable (as showing in the tutorial).
Could you try to change the onpageunload by an onclick and try again please?
Same thing, on the next page i get 1 empty checkbox. instead of only the selected values
Could you send the prototype to jim.support@justinmind.com to check it please?
email send
thank you for your support.
checkboxes are working now
Can you tell us the solution? Thank you
you have to use a click event to store the variable, and page load (select value) event to select the selected variable in the checbox
That's not my problem but thanks anyway
You can display the checkbox value only in another checkbox. That's what you are trying to do?
