carousel widget
fred shared this question 4 years ago
Is there a detailed set of instructions somewhere that someone has on how to set up the carousel widget correctly? I want the carousel to "spin" on swipe left or swipe right gestures.
Dave.
You can try adding a 'Hotspot' widget in every panel of the main Dynamic Panel covering the whole carrousel. They will be used to capture your gesture interaction.
Then for each panel, copy the events defined in the left and right arrows to the Hotspot but use 'on Swipe Left' and 'on Swipe Right' events instead of 'on Click'.
I hope it helps.
Thank you ill try this and see how i go :)
