Can't launch Justinmind
alexis.toyane shared this problem 7 years ago
I just installed Justinmind but everytime I try to launch it, I've got this error message :
An error has occured, see the log file : ...
Here is the log file :
!SESSION Fri Feb 03 22:59:54 CET 2012 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2012-02-03 22:59:54.838
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:616)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Comments (7)
Are you launching it from a Mac or from a MS Windows?
From Windows 7 Professional x64
Could you check something for me please? Could you open the Justinmind's installation folder and then the folder called 'plugins', and check if there is any file with .pack extension?
I can't to this right now (I don't have my laptop with justinmind) but I will check asap.
Indeed I have a .pack file : org.eclipse.osgi_3.6.0.v20100517.pack
Ok, that means your antivirus blocked one of the steps of the installation. Uninstall Justinmind Prototyper, download it from here http://d2ld3he4yll0xl.cloudfront.net/... and install it again please.
