can't generate html file from .vp
pletmpa shared this problem 7 years ago
Dear Supporter, i can't generate html files or share online my .vp file. Error mesage " an unexpectes error is ocourred". I check out logs.log :
INFO[2011-08-30 13:26:12,732]- processing Css
INFO[2011-08-30 13:26:12,732]- processing BrowserItem
INFO[2011-08-30 13:26:12,733]- processing CssIE
INFO[2011-08-30 13:26:12,740]- processing Data
INFO[2011-08-30 13:26:12,748]- processing Event
INFO[2011-08-30 13:26:12,753]- processing ViewAnnotated
ERROR[2011-08-30 13:26:12,792]- generation failed:
com.justinmind.generator.engine.GenerationException: com.justinmind.generator.engine.GenerationException: java.lang.ClassCastException: com.justinmind.evc.model.businessObjects.BusinessObject cannot be cast to com.justinmind.evc.model.actions.GridView
at com.justinmind.generator.engine.Generator.createContexts(Generator.java:144)
at com.justinmind.generator.engine.Generator.generate(Generator.java:100)
at com.justinmind.generator.engine.Generator.startGeneration(Generator.java:75)
at com.justinmind.evc.igu.actions.w.run(w.java)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: com.justinmind.generator.engine.GenerationException: java.lang.ClassCastException: com.justinmind.evc.model.businessObjects.BusinessObject cannot be cast to com.justinmind.evc.model.actions.GridView
at com.justinmind.generator.context.ContextFactory.createContexts(ContextFactory.java:68)
at com.justinmind.generator.engine.Generator$ParallelGenerator.run(Generator.java:232)
Caused by: java.lang.ClassCastException: com.justinmind.evc.model.businessObjects.BusinessObject cannot be cast to com.justinmind.evc.model.actions.GridView
at com.justinmind.generator.context.EventContextFactory.processGroupEventAction(EventContextFactory.java:654)
at com.justinmind.generator.context.EventContextFactory.processGroupEventBlock(EventContextFactory.java:545)
at com.justinmind.generator.context.EventContextFactory.processGroupEventCase(EventContextFactory.java:532)
at com.justinmind.generator.context.EventContextFactory.processGroupEventFirer(EventContextFactory.java:479)
at com.justinmind.generator.context.EventContextFactory.processGroupEventDelegate(EventContextFactory.java:273)
at com.justinmind.generator.context.EventContextFactory.processGroupEvent(EventContextFactory.java:147)
at com.justinmind.generator.context.EventContextFactory.createContexts(EventContextFactory.java:133)
at com.justinmind.generator.context.ContextFactory.createContexts(ContextFactory.java:64)
... 1 more
can you help me ? If you need my file let me known.
It seems to be a bug related to a specific type of event. It is very likely to be coming from a 'Pagination Action' defined with wrong parameters (a Data Master). Please notice that 'Pagination Actions' are ment to have a Data Grid as a paremeter instead of a Data Master. If you have problems identifying and fixing the wrong expression please send your prototype at jim.support@justinmind.com and we will fix it for you.
We will surely fix this bug for the next version. Thanks for you feedback and sorry for the inconvenience.
many thanks Bernat, i changed the pagination actions to my Data Grid and it works now!
Thanks for your support
Greetings from Berlin
