Can't change font size in certain widgets
frankdahle shared this problem 7 years ago
Having problems with changing font size in the rich text and table widgets! I select the text, change font size from 10 to 11.. but after deselecting the text, the font is still 10. Please advise, how should font formatting be done? 0f2426c6f8b40c3e8c06d7e9d6408653
Comments (4)
Explaining the image:
first widget is the TEXT widget, and changing font size is ok (here it is 11).
Next 3 are RICH TEXT widget, and Im not able to change them to font size 11
Bottom right there is a table, and im not able to change font size there either.
whats wrong?
May I ask you how do you change the font size in both Rich text and table? Do you double click on them and then change it? Do you just select the item? Do you use the font size selector at the top tool bar or the one in the Properties panel at the left? (Sorry for so many questions)
Most things (like labels and buttons) I can have selected and change the font. But things like the select list doesn't allow me to change the font.
Use the custom select list widget instead.
