Can't activate JustInMind Prototyper pro 5.1.0
Christiaantje85 shared this problem 6 years ago
I used the Justinmind 5.1.0 30 Days trial, it was an pleasant experience so I purchased a key. Now I want to activate my application but it doesn't work.
If I start JusitInMind it asked for my key, when it is checked I get the message "the key has been registered successfully and the application needs to be restarted".
after restarting the application it starts asking me for the key again.
What to do?
I'm not the only one with this problem but I can't find the right solution.....
Now I reistalled the application but it wont help.
The order for the key was placed on 16 Jan 2013.
The error that you describe can be related with a change occurred in your system clock. If, for any reason, you or a software in your computer changed your system clock then the license systems thinks you want to crack it.
Please send your license key to client support (jim.support at justinmind.com) and we will fix it for you.
