Can't maange to filter and group
Josselin Guibert shared this problem 4 years ago
Hi all,
I have the following issue, imagine the following data master
Header - Cat - Sub Cat
H1 Cat1 SubCat11
H1 Cat1 SubCat12
H2 Cat2 SubCat21
H2 Cat2 SubCat22
H2 Cat3 SubCat31
Now I want the user to go through category by category reducing filtering and generating unique values every time:
Panel 1:
H1
H2 -> Selected by user
This implies that next panel 2 will show
Cat2
Cat3 -> Selected by user
Finally shows the value SubCat31.
Now the problem I have is that I don't seem to be able to select columns of a table like in SQL to apply a filter on. Hence the function "Filter Distinct" applies to the whole data master (and do not filter anything since the Sub Cat values are unique).
This must be a common request and I'm sure you have a solution but I just can't find it and getting a bit frustrated.
Many thanks,
Jos
Comments (4)
Hello Jos,
To use the header values, you may simply use the filter function as seen in the following tutorial:
http://www.justinmind.com/support/fil...
If you require additional help, you may submit your prototype file to jim.support@justinmind.com and we'd be happy to take a look.
Regards,
Luisa
Thanks,
I of course seen that but this does not solve the issue as from above explain I need to create unique values.
Kind regards,
Josselin
Exported to JustInMind customer support portal
Thanks Luisa, note that I sent an email with data to the adress provided above.
