Cannot run Prototyper Pro on Mac 10.8.3. Have no idea what is going on. Below is the log file. Any help?
Kann Vearasilp shared this question 5 years ago
!SESSION 2013-04-27 01:27:07.144 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_45
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -keyring /Users/kann/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Pro.app/Contents/Resources/Java
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -data @user.home/Justinmind/5.1.0 -keyring /Users/kann/.eclipse_keyring -showlocation WorkingDirectory /Applications/Prototyper Pro.app/Contents/Resources/Java
!ENTRY org.eclipse.ui 2 0 2013-04-27 01:27:11.021
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2013-04-27 01:27:11.021
!MESSAGE Cannot bind to an undefined command: plug-in='com.justinmind.evc', id='org.eclipse.ui.edit.redo.command'
!MESSAGE Key bindings should not have an empty or incomplete key sequence: plug-in='com.justinmind.evc', id='org.eclipse.ui.help.helpContents', keySequence='COMMAND+SHIFT+'
!ENTRY org.eclipse.ui 4 4 2013-04-27 01:27:11.084
!MESSAGE The proxied handler for 'com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler' could not be loaded
!ENTRY org.eclipse.ui 4 0 2013-04-27 01:27:11.084
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in com.justinmind.evc was unable to load class com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:350)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:319)
at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:107)
at org.eclipse.ui.internal.handlers.HandlerPersistence.readDefaultHandlersFromRegistry(HandlerPersistence.java:258)
at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:213)
at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167)
at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.ClassNotFoundException: com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-04-27 01:27:11.086
!MESSAGE Plug-in com.justinmind.evc was unable to load class com.justinmind.evc.igu.dialogs.handlers.EVCAboutHandler.
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2013-04-27 01:27:11.092
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2013-04-27 01:27:11.092
!MESSAGE Conflict for 'org.eclipse.ui.help.aboutAction':
HandlerActivation(commandId=org.eclipse.ui.help.aboutAction,
handler=HandlerProxy(),
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.about.AboutHandler,
!ENTRY org.eclipse.osgi 4 0 2013-04-27 01:27:12.199
!MESSAGE Application error
!STACK 1
java.lang.VerifyError: (class: com/justinmind/evc/igu/actions/he, method: run signature: ()V) Incompatible argument to function
at com.justinmind.evc.igu.main.actions.d.a(d.java)
at com.justinmind.evc.igu.main.actions.a.a(a.java)
at com.justinmind.evc.igu.main.zh.preWindowOpen(zh.java)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(WorkbenchWindow.java:1328)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:413)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1925)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1923)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1207)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
Comments (6)
Take a look at this other thread:
I did remove everything inside ~/Justinmin/5.1.0
Once the application restarted, it asked to create a configuration inside ~/Justinmind again. However, I still got the same error, and below is the log file...
!SESSION 2013-04-27 10:56:25.485 -----------------------------------------------
!ENTRY org.eclipse.ui 2 0 2013-04-27 10:56:33.942
!SUBENTRY 1 org.eclipse.ui 2 0 2013-04-27 10:56:33.942
!ENTRY org.eclipse.ui 4 4 2013-04-27 10:56:33.983
!ENTRY org.eclipse.ui 4 0 2013-04-27 10:56:33.984
!STACK 1
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-04-27 10:56:33.985
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2013-04-27 10:56:33.991
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2013-04-27 10:56:33.991
!ENTRY org.eclipse.ui 4 4 2013-04-27 10:56:37.589
!ENTRY org.eclipse.ui 4 0 2013-04-27 10:56:37.590
!STACK 1
at org.eclipse.ui.internal.handlers.HandlerAuthority.deactivateHandler(HandlerAuthority.java:292)
at org.eclipse.ui.internal.handlers.HandlerService.deactivateHandler(HandlerService.java:148)
at org.eclipse.ui.internal.handlers.HandlerService.deactivateHandlers(HandlerService.java:157)
at org.eclipse.ui.internal.handlers.HandlerPersistence.clearActivations(HandlerPersistence.java:104)
at org.eclipse.ui.internal.handlers.HandlerPersistence.dispose(HandlerPersistence.java:125)
at org.eclipse.ui.internal.handlers.HandlerService.dispose(HandlerService.java:163)
at org.eclipse.ui.internal.services.ServiceLocator.dispose(ServiceLocator.java:142)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3057)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1123)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1040)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1284)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1282)
at org.eclipse.ui.internal.Workbench.restart(Workbench.java:2292)
... 65 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-04-27 10:56:37.591
!STACK 0
!ENTRY org.eclipse.ui 4 4 2013-04-27 10:56:37.677
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2013-04-27 10:56:37.677
!MESSAGE java.lang.NullPointerException
!STACK 0
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3576)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:419)
!SESSION 2013-04-27 10:56:38.685 -----------------------------------------------
!ENTRY org.eclipse.ui 2 0 2013-04-27 10:56:42.049
!SUBENTRY 1 org.eclipse.ui 2 0 2013-04-27 10:56:42.049
!ENTRY org.eclipse.ui 4 4 2013-04-27 10:56:42.094
!ENTRY org.eclipse.ui 4 0 2013-04-27 10:56:42.094
!STACK 1
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2013-04-27 10:56:42.096
!STACK 0
!ENTRY org.eclipse.ui.workbench 2 0 2013-04-27 10:56:42.102
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2013-04-27 10:56:42.102
!ENTRY org.eclipse.osgi 4 0 2013-04-27 10:56:43.035
!STACK 1
Well, that was just one of the three steps. Yo need to follow all the steps to make it work.
Hi Victor, below is what I did.
1. The Prototyper Pro always crashes itself. Therefore, it didn't stuck at the menu bar. There's just nothing, so I didn't actually re-close the program since there's nothing since the beginning.
2. I deleted ~/Justinmind/5.1.0
3. I re-opened Prototype Pro by double-clicking its icon in the /Applications directory
4. The Prototype Pro asked me to create all the configuration files in ~/Justinmind/5.1.0 again
5. The program crashes
6. go back to 1.
You missed step 3 on these instructions:
Hi Victor,
I do not quite understand what you mean. What I did was deleting the content of 5.1.0 like what you stated here:
3. Go to your user folder then open ‘Justinmind’ folder and remove all the contents inside it ( 5.0.0, 5.1.0, ...).
The command was 'rm -rf ~/Justinmind/5.1.0/*'
Restarted the Prototyper Pro, and still got the same result...
