Cannot Modifying images of a Data Grid
Normanb shared this problem 6 years ago
I have been trying to modify images in a data grid
I have followed the video tutorial and can successfully modify the text areas of the data grid
However I can not remove or replace or modify an image
If the image has never been loaded previously into the data grid row it will work to upload/modify and load the new image into the place of an absent image in the data grid of the row I am editing
But alas I cannot get it to simulate the swap of a old image with a new image
ANY IDEAS ....?????
Comments (4)
You can't upload image files to your Prototype in Usernote. The best thing is to have some predefined images in your prototype and simulate just a few predefined cases.
Hey Victor
I am not using usernote but the simulate button directly from justinmind prototype
I followed the tutorial which has the car image changed/ modified from a wagon to a convertible yet it won't do it when I follow the instructions exactly .... text changes are not a problem to modify on the data grid only the image file ??
Victor
I also have been able to upload an image when the item I am modifying previously had no image loaded in that row of the data grid ?? thus it seems that it cannot modify the imiage if one is present yet it did in the tutorial video ??
Well, I think that should be working. Could you send the prototype to jim.support at justinmind.com please? We will check it out and see what could be the problem with it.
