Can we change an image value with an image data field?
Benjamin Mourlon shared this question 6 years ago
Is it possible to change an image value with an image data field of a data master?
For example, an image of a product on his description page?
I tried to change value with expression builder :
select(filter(Product, (ID = ActiveProduct)), Image)
But unfortunately... it's not the good way.
So... is it possible?
Comments (7)
Yes, you should be able to. Could you describe me your prototype a bit further please?
Can I have an email to explain you my project? It's too much innovative to share it here and there are more than 1 question to ask you to be honest.
Sure, send it to jim.support at justinmind.com
Ok, I will write it asap.
I tried something simple to confirm my problem :
1) Create a data master Test with 3 fields : ID (text) ; icon (file upload) ; title (text)
2) Add an entry : ID = 1 ; a picture (i tried jpg and png) ; Test
3) Add an image and a label on the canvas
4) Add on page load interaction on each : set value with that expression :
Select(Filter(Test, (ID = '1')), field) [field = icon for image and title for label]
Only the label will be modified.
That same example seems to work fine. Could you send us that simple prototype please?
Ok, I found the problem, it works with Simulate, but not with preview, not really a problem, sorry.
Yes, that could be happening. Thanks for reporting.
