Can I use a variable to change the size of a container or row?
mike.parziale shared this question 7 years ago
I'd like user data to resize rows
You mean to set the height of a row dynamically from a variable (so if the variable holds '78' then the row is '78 pixels' height? Or just check a variable and then choose from a different predefined heights?
I mean if '78' then it's '78 pixels' height?. I want the user to resize the object on drag or to set the size based on previous data.
I'm afraid I have to say that you can't do that in Prototyper. You just can set a predefined cases and then simulate that cases.
