Can i save my prototype in higher quality images?
Alex Dagil shared this question 6 years ago
I think the quality of the image is very bad, and i would like to scale it up. Doesn't seem to be an option.
Comments (4)
Hi Alex,
Please can you tell me which option are you using to export the images?
I'm using the 'save as images' function.
Currently the "Save as images" option can only export the images to ".jpg" files, we are going to fix this on our next release by exporting the images to ".png" files so the image quality will be improved.
If you are using Prototyper Pro instead of using the "File->Save as images..." option, you can select the canvas of the screen you want to export and select the option "Edit->Save as image". This way the screen will be exported to a ".png" image.
May be it would help. Desperately need to see PNG, BMP and other qaulity control options in Prototyper or at least create a plugin.
