can I import Keynote files in Justinmind?
Dan Pen shared this question 4 years ago
I created a low-fidelity prototype in Apple Keynote. If I export it as a .KEY file or PDF it retains the links. Otherwise I can export each screen as PNG.
you can import png files and add links using image map. Here you will find how to do it: http://justinmind.com/prototyper/lear...
Best regards,
Thank you Albert--it worked!
Is there any way to retain the links that I had already added in Keynote?
it's not possible to do it.
Sorry for the inconvenience,
