Bootstrap Button DropDown Won't Collapse
mister5280 shared this problem 5 years ago
I added a bootstrap drop down button widget to my prototype. It renders the dropdown function once but then on second or subsequent clicks it will not collapse when in simulation mode. Has anyone else experienced this?
Comments (6)
You can make the widget collapse using a dynamic panel. For example, you put the collapsed state of the widget in panel 1 while you put the expanded state in panel 2. Here's a video tutorial how to do it: http://justinmind.com/prototyper/lear...
Ok John,
I do see that and was able to implement that method. I guess I was thinking these would perform as a functioning widget out of the box.
Ok, I will tell our product manager about it. Maybe it will be included in our future release.
I told him about it, and here's what he said.
"Tell him he can define an ‘on focus out’ event -> hide submenu’ on each item. Or better, you could download the library, change that widget and send it to him."
Do you want me to send you the Bootstrap library with the necessary modifications or you already changed your drop down button widgets?
Hi John,
I just modified the widget and saved it back to my library as a new one. I am going to try the on focus out -> hide submenu method as well.
Cool.
