Best way to add links, bold/italic text to copy
markedup shared this question 5 years ago
What's the best way to add links and bold/italic text to blocks of copy?
Use the rich text. Then select the piece of text you want to format and use the tools in the toolbar or the keyboard shortcuts. If you want to make a piece of text clickable you just need to place an image map over it.
Ah, thank you. I was trying to do this (i.e. select and alter a piece of text) via the 'Properties' box, which didn't work and was quite confusing.
