Arranging display order with event...
Seong shared this question 5 years ago
If you have two dynamic panels (one of them as hidden) overlapped on top of each other with an event associated with it, the panel that is supposed to show from hidden state with a click event will hide the overlapped part by the other panel although I set the order correctly which goes on top.
It occupies more space and doesn't look nice because of this weird behaviour...
Could you send an example to jim.support at justinmind.com please?
It is working as desired now. I had to make sure when placing those panels each panel doesn't contain one another.
The outline tab could help you with that.
