Apparent Bug: OnDragStop w/InsertInto for >2 targets Crashes JIM.
Ken Gustafson shared this problem 5 years ago
Apparent Bug. Setup: JIM 5.5; 3 independent/single-layer dynamic panels (P1/P2/P3 vertical layout); 1 rectangle R1. R1 has OnDrag_withCursor event. Adding R1 event "OnDragStop/ WhenDropOn=P1/ InsertInto P1" works. Adding 2nd R1 event "OnDragStop/ WhenDropOn=P2/ InsertInto P2" works. Adding 3rd R1 event "OnDragStop/ WhenDropOn=P3/ InsertInto P3 CRASHES. JIM error "An unexpected error has occured...We will try to fix this error on the next update." Program exits, usually corrupting .vp file.
I am unable to reproduce your issue. Can you please send your .vp file to jim.support@justinmind.com?
Hi Ken,
could you send a prototype where this bug happens? We are unable to reproduce your issue and we would like to run some test.
Hello Albert,
Just sent over (to jim.support@justinmind.com) a simplified proto, with instructions on how to reproduce. Let me know if you need anything else.
Thanks for looking it over.
