Adding multiple Filter conditions on a dataMaster Modify action
Vivek Anand shared this question 6 years ago
Hello JustInMind!
How to update a datat master with two filter conditions? the brackets in filter Box do not allow me to place "&" for adding another condition. Any help?
For example:
SQL : Update table set status=5 where id=1 & code =1 .
I would like to do the same in the prototyper dataset. Please help
Comments (7)
Hi Vivek,
The expression looks pretty much as your SQL statement:
0017e3075f2da826a3b5cbe91a7500fe
Yeah it works! :)
Thanks a lot for the quick reply.
The brackets were little bit confusing as we add up more conditions. My suggestion would be to stack the filters with & rather than adding them on the single line.
Like:
2181c769a209d5d0cd1c69a4d27b2f70
just a thought.
btw, JIMP is a great tool :) everybody here likes it!
Even though this distribution is more readable it takes up a lot of valuable space. An expert mode where you simply write these expressions is a better option:
6a973cc5b71c472a7a659e89fdfa2742
PS: with what program do you think i took this screenshot :-)
Yeah I actually tried to find something called "Justinmind prototyper scripts" in google. :)
This expert mode looks almost like a script, but how I can hand edit the text?
When I try to edit the text, it takes me again to the drag-blocks screen.
PSR: MS Snipping tool?
so far it's for visualization only. an expert editing mode would be a nice feature.
PSR(R?): Gimp!
PSR -> (R)eply to your PS! :)
Thanks for the help Burk! Completing my proto works now :)
