Add text to Label - 'double click' not working
Lewis Price shared this problem 6 years ago
Within the new version it seem that the 'double click' on a label doesn't then allow you to change the text the within the label. You need make this change directly in the Value field in properties.
Is this by design?
Hi Lewis,
Are you sure you are using the last version? I say so because that was a bug in one of the first beta versions we launched.
Is your label inside a group or something special?
