Hi All,
I badly want to try out JustinMind for a new app we are building, but its hard coded PATH search prevents it from finding my JRE.
Here is the error message when I try to run Prototyper Pro:
"No Java virtual machine
was found after searching the following locations:
/Applications/Prototyper Pro.app/Contents/MacOS/../../../jre/Contents/Home/jre/bin/java
java in your current PATH"
When I go to Terminal, "java -version" reports:
java version "1.7.0_55"
Java(TM) SE Runtime Environment (build 1.7.0_55-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.55-b03, mixed mode)
and "which java" reports:
/usr/bin/java
My env is configured in /etc/launchd.conf
Mac OS X, 10.7.5
Thanks for any help. We have a presentation this Thurs where I hoped to showcase some ideas to our client. Mockflow sucks, so I would really like to try this out.
Greg
Oh yes, and I also removed all files from the /System/Library/Java/Extensions folder just in case - no effect.
I run a complex environment - after messing around with the order in which my PATH is built, I was able to fix the issue.
