"Round" property for Data Grid does not appear to work.
Michael Magoon shared this problem 7 years ago
Not a Problem
The "Round" property for Data Grid does not appear to work. I can change the value within the Dynamic Panel properties area, but it has no affect on the object.
Comments (5)
The Data Grid's don't have the 'Round' property. If you change the one in the 'Dynamic Panel' properties then you are rounding the dynamic panel instead.
Sorry, I should have said "Round" property for Dynamic Panel does not appear to work. I can change the value within the Dynamic Panel properties area, but it has no affect on the object. I have tried a number of different objects with the same result.
Now I get it. You have to go to the border properties and select the type of border (solid, dotted, dashed). By default the type is 'no border'. That's why the round property is not applied.
Makes sense, but I think that the Round property control should display as inactive if user cannot act upon it.
Yes, that might help.
