"On Change" Event doesn't seem to work
Niles Plante shared this problem 5 years ago
I have tried even simple tests of the "On Change" event and it never triggers anything. Am I doing this wrong or is this just broken? Can you point me toward any protoyper file that has this working correctly so I can compare my usage to a functional usage?
It is working. You can try this.
drop these widgets onto your screen: rectangle, checkbox, text, and radio button
select the checkbox -> Add Event -> On Change -> Change Style -> select the rectangle -> change the background color then click ok
Now do the same for the text box and radio button widgets.
Simulate it. Observe that when you click the checkbox, the color of the rectangle changes.
