Prototyper don ́t run in Mac Mountain Lion
Ramón Cidrás shared this problem 5 years ago
Solved
First sorry for my English.
The Prototyper Pro 5.1.0 not run in my mac (OSX 10.8.2) and the Java version 7 update 9. I probe to install many times, deleting all the files of Justinmind, and I read other similar problems in this web, but not resolve my problem.
The program installed apparently correctly, but appears this windows
f738152e0e1021e3310fac1b33690faf
The program closed, and the next time not run.
The log is this:
[main ] [2012-11-25 23:47:54] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2012-11-25 23:47:58] ERROR com.justinmind.prototyper - com.justinmind.evc.igu.main.yh@480d41f3
java.lang.NullPointerException
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:3576)
at org.eclipse.ui.internal.WorkbenchWindow.(WorkbenchWindow.java:419)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWorkbenchWindow(Workbench3xImplementation.java:31)
at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1925)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1923)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java:1207)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3621)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.justinmind.evc.igu.main.Application.run(Application.java)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
[main ] [2012-11-25 23:47:58] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2012-11-25 23:48:02] INFO com.justinmind.prototyper - START Justinmind Prototyper
[main ] [2012-11-25 23:48:09] INFO com.justinmind.prototyper - Open default project
[main ] [2012-11-25 23:48:17] INFO com.justinmind.prototyper - Activate Tab: COMMENTS
[main ] [2012-11-25 23:48:18] INFO com.justinmind.prototyper - Activate Tab: USER_INTERFACE
[main ] [2012-11-25 23:48:19] INFO com.justinmind.prototyper - Activate Tab: USER_INTERFACE
[main ] [2012-11-25 23:48:26] ERROR com.justinmind.prototyper - Bad license
[main ] [2012-11-25 23:48:26] ERROR com.justinmind.prototyper - com.justinmind.evc.igu.main.yh@5eb2c603
at org.eclipse.ui.internal.Workbench.disposeApplicationMenu(Workbench.java:3904)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3054)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1123)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:1040)
at org.eclipse.ui.internal.Workbench$25.run(Workbench.java:1284)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1282)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1254)
at com.justinmind.evc.igu.main.zh.b(zh.java)
at com.justinmind.evc.igu.main.zh.postWindowOpen(zh.java)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1365)
at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:826)
at org.eclipse.ui.internal.Workbench$24.runWithException(Workbench.java:1243)
[main ] [2012-11-25 23:48:26] INFO com.justinmind.prototyper - EXIT Justinmind Prototyper
[main ] [2012-11-25 23:48:41] INFO com.justinmind.prototyper - START Justinmind Prototyper
Comments (3)
Let's try something first. Could you please follow these instructions?
Follow the instructions in this article to let your Finder see hidden files and folders: http://www.mikesel.info/show-hidden-f...
Then open this folder /etc/Justinmind/.license (this route begins in your Hard Drive). Remove everything that is inside that folder.
Remove Prototyper from Applications and install it again.
Ok. The program run now propertly.
Only a note: the folder is /etc/JustinmindPrototyper/.license
Hi
I've had the same problem, I followed these instructions, and it says the application has been successfully installed, but it's no where on my system.
