Windows 10 startup crash
In Progress Gnarvster 6 years ago
Hi , windows 10 startup crash. Tried reinstalling several times and restarted fresh. Tried starting as administrator. No avail.
Problem: "[removed]\Justinmind\8.7.4\configuration\org.eclipse.osgi\bundles\5\1\.cp\lib\jim-usernoteclient.jar (Access is denied)"
First, can you check to see if this file exists on your computer?
If it does, check to see if your user has read/write permissions for that file.
Yes/yes
Ok, thanks for the info. Can you attach an additional log file? You can find it by following this file path:
C://users/youruser/Justinmind[version]/metadata\.bak_0.log
It might be listed under another name - any file with .log in this folder would be helpful.
Additionally, we saw in our database that you have published prototypes to your online account in the past before. Were you able to open Justinmind and publish these prototypes on another computer?
