Getting issue while adding text messaging prototype
In Progress Jacklinexavier 7 years ago
After following the steps mentioned in https://www.justinmind.com/support/designing-a-text-messaging-app/ url, I am not able to get the chatbox functionality properly. When I enter few text and click on send, keypad is not visible and the message is not shown in the
If possible, can you attach the prototype you've created so we can see what isn't working? You can compress the file to .zip/.rar format to attach it here.
Thanks for your response. Attaching the prototype created.
1) Only iPhone prototypes have the keypad, so in an Android phone you will not see the keypad movement.
2) You had the Data Grid set to show only 1 cell, when it should read '0' (which means all cells will show when added)
Check out the attached edited prototype
