Input Text Field replacing Value to Placeholder as of 8.6
In Progress Gail 7 years ago
With the most recent update of Justinmind, I have run into an issue with adding value text to Input text fields. Currently, when I add a value to an input field, it only accepts single line text instead of allowing for multiple lines (even when adjusted to textarea under the type). Additionally, when double clicking to edit the text on the input text field, it turns the text gray and transfers it to the placeholder area, removing the value completely.
This has been extremely detrimental to the progress on a prototype as I tend to use Input text fields to store values, as editing my values completely removes them as values and puts them as placeholders, which is not what I want. Is there a way to fix this, or is this just a current bug of the system?
Thanks for letting us know about this. I have let our development team know and we'll find a fix for this.
However, I haven't been able to reproduce the first issue you describe - where you can't add multi line text. Can you list the steps you take for this issue to occur?
