Upvote 4
Someone has problem with border rounds to?
In Progress Ullisses Castro ● 9 years ago
The border round does not change in some cases
Hi Ullisses,
If possible, can you describe the steps that led to the border not rounding? We'd like to be able to reproduce this.
I'm bumping this, I just downloaded JIM, and rounded corners don't work at all.
I simply added an input text field and went to the properties changed "round" to 3, and nothing happens. I have to change it to around 15 before it starts rounding and by then the lines just look horrible.
Hi Matt,
The borders are rounding, it's just quite subtle. If you make the input field larger you can see that they are rounding.
It’s definitely not rounding the corners... the values are all off.
If I put value 25, then the css output shows border radius 3px. So the math or conversion is completely off...
Secondly if you do make it at that high value the borders look completely wack. It’s not hard to try it out yourself to see. If you zoom in closer you can see an input field is made of four separate lines, not one continuous rectangular border.. this is probably causing the problems.
In any case if rounded corners don’t work or make our product look wacky then at this point the software for demo purposes is rendered useless at this time.
It's definitely not working for me either.
I have the same problem. Borders get rounded in JIM environment but in the simulator it i not applied.
That is odd - would you be able to attach that prototype here so we can check this out? You can compress it to .zip/.rar format to attach it here.
Same problem here. Also another problem to compound this, in JIM the sizing is completely off versus in simulator.
To reproduce:
  • have whiteboard to 1500x1800
  • Horizontal layout and center / center
  • create dynamic panel with 100% width and 29% height
  • 10% container padding
  • insert buttons (I have 4 for example)
  • 19% width and 80% height looks like what I want in JiM
  • HOWEVER 100% height gives closer to desired effect in simulator. Messed up.
  • Also find it completely unintuitive that the text doesn't resize with resolution change, as well as when changing opacity of the button that it also changes the opacity of the text simultaneously
Images attached.
Hello, would you be able to attach that prototype here so we can check this out?
