justinmind-logo
Upvote 5
Copy/Pasting from Illustrator
Solved Victor Conesa 8 years ago
When I copy my (1024) layout from Illustrator and paste it into JIM it comes in as 1366. I can't figure out how to make any resolution adjustments to fix this. Any ideas?
Replies (11)
Hi Tijmen,
Thanks for sharing your solution!
Hi Jason,
Your request has been answered through our Customer Support Portal.
Hi Mariko Kyo,
Which Justinmind / Illustrator versions are you using? We've done the test with the most recent versions of Justinmind (7.6.0) and Adobe Illustrator CC 2017 (21.0.0) and it's working without any issues.
Hi Sonia Duran.
Thank you for the reply.
I use Illustrator CS6.
Would you be able to lend your expertise?
My earlier message: Additional comment
Justinmind versions is 7.6.0.
Sincerely,
Hi Mariko,
We will need to do some tests to find out what is the source of your issue. If possible, can you send me the SVG file you are trying to copy paste ? If is not a SVG file please send me the .AI file (compressed the files into .rar to attach them here)
Hi Sonia,
Thank you for your support!
I have attached the file.
But this problem is not only this file,but also other files.
Best regards.
Hi Mariko,
After some investigation we have detected that the source of your issue is that the dropshadows that you have applied to the object is not compatible to the copy / paste action. Please find attached the file without any dropshadow applied.
Hi,Sonia.
Thank you for your support.
I tried it,but I can't...
I have attached other file again.
Sorry for bothering you,but could you look it up?
This file's left is drag and drop,and right is copy and paste.
I can't see the right.
Best,regards.
Files: 0207.zip
Hi Mariko,
I've analised again your file. The reason is also that you've applied a round corner effect that is not compatible with the copy-paste action. You should use the Rounded Rectangle Tool instead.
Hi Sonia,
Thank you very much for your help.
I tried it,but I couldn't...
Sorry to keep bothering you.
Best,regards.
Hi Mariko,
We've been checking again your file. This time we haven't been able to reproduce your issue as it works with our Illustrator version, so Unfortunately your issue seems to be related with version you're using. Sorry for any inconvenience.
Hi Sonia,
Thank you for your assistance.
Unfortunately I will give up.
I'm glad I understood it.
Best,regards.
Mariko Kyo
Dear Lucas,
Unfortunately, we haven't been able to reproduce your issue with Illustrator 2017 and 2018. Which OS and version are you using?
I have the same problem. I have updated 2018 InDesign and Illustrator. The copy and paste will not work between the two programs, nor is it working right in Illustrator itself, even within the same file. At this point I have to create a new layer to copy and paste within Illustrator. I have seen the red rectangle bitmap etc. but not every time.
I use Windows 7 and this only started with the update to 2018
Dear Charles,
We're trying to reproduce your issue. I'll get back to you ASAP.
Thanks Sonia!
Dear Charles,
We've been trying to reproduce your issue (in a Windows7 device with the latest update of Illustrator ) without success. We have been able to copy / paste without any problems. Which Justinmind version are you using?
*With Indesign there is no possibility to copy/paste.
We've just published our Illustrator plugin. You can now export your designs from Illustrator and continue working in Justinmind. Check it out here.
