How can I made my prototype into responsive one for any mobile device?
I have done a mobile prototype for my school jobs. I made it with 568x320 custom screen size.
I do not know my mobile phone screen size actually.
But when I run it on my mobile, the prototype is really smaller and elements are not fixed with the screen.
Can I make it into "responsive" to be adjusted with any screen that I view/run.
Waiting for detailed reply soon. Thanks.
Hi Hhlynn Nai,
You can find information about adaptative and liquid layouts in the tutorials section in our website:
http://www.justinmind.com/prototyper/...
http://www.justinmind.com/support/res...
I hope it helps.
Hi Team,
any updates about this issue ?
Merci
The two properties you need to use to make responsive prototypes are pin positions, and % widths/heights.
Pin Position - find in the Properties palette, under the section Position. Pin positions will pin an element to a certain part of the screen. If you want to make a 'sticky' header, use pin position, and change the 'y' parameter to 'pin to top'.
% width/height - find in the Properties palette, under the section Size. % size will change the size of an element to be responsive to the size of the screen.
Check out the attached prototype. Let me know if you have any questions.
